Engineering Solutions
Node Based Surface
Node Based Surface
This is the first topic This is the last topic No expanding text in this topic
Node Based Surface
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Node Based Surface dialog allows you to define and edit the *SURFACE, TYPE = NODE card.  There are three tabs in this window:
Define
Delete Surface Node
Optional Parameters
node_based_define_tab
The Node Based Surface dialog contains the following buttons:
Surface color
Changes the color of the current surface in the graphic area.
Review
Reviews the current surface by highlighting it in white and displays it through solid mesh in the graphic area.  If the surface is defined with sets, the underlying nodes are highlighted.  Right-click on the Review button to clear the review selections.
Close
Updates the Engineering Solutions database with the optional  parameters specified and closes the Node Based Surface window.
See Also:
Contact Pair
Pre-Tension Section
Tie
General Contact
Auto Contact
Element Based Surface
Surface Combine or Crop
Cutting Surface
Analytical Rigid Surface
Surface Interaction
Abaqus Contact Manager
