Engineering Solutions
Contact Pair
Contact Pair
This is the first topic This is the last topic No expanding text in this topic
Contact Pair
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Contact Pair dialog allows you to define the *CONTACT PAIR card.  Options vary according to the active template.  There are two tabs in this dialog.
Define
Parameter
ab-con-man13
The Contact Pair dialog contains the following buttons:
OK
Updates the Engineering Solutions database with the changes and closes the Contact Pair dialog.
Apply
Updates the Engineering Solutions database with the changes without closing the Contact Pair dialog.
Cancel
Closes the Contact Pair dialog without updates.
See Also:
Pre-Tension Section
Tie
Auto Contact
Element Based Surface
Node Based Surface
Surface Combine or Crop
Cutting Surface
Analytical Rigid Surface
Surface Interaction
General Contact
Abaqus Contact Manager
