Engineering Solutions
Node Based Surface: Optional Parameter Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Optional Parameter tab allows you to define optional parameters for the *SURFACE card.
The supported parameters are:
Standard.3D/2D template: Trim
Explicit template: Max ratio, Scale thickness, Region type, No offset and No thickness.
See the Abaqus Online Documentation for a detailed description of these parameters. Click on the Update button to activate the optional parameter selection in the Engineering So0lutions database.
node_based_optional_parameter_tab
