Engineering Solutions
Pre-Tension Section
Pre-Tension Section
This is the first topic This is the last topic No expanding text in this topic
Pre-Tension Section
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Pre-Tension Section dialog allows you to define the *PRE-TENSION SECTION section and related assembly loads and constraints.  This dialog contains two tabs:
Define
Parameter
ab-con-man17
The Pre-Tension Section dialog contains the following buttons:
OK
Updates the Engineering Solutions database with the changes and closes the Pre-tension Section dialog.
Apply
Updates the Engineering Solutions database with the changes without closing the Pre-tension Section dialog.
Cancel
Closes the Pre-tension Section dialog without updates.
