Engineering Solutions
Surface Combine or Crop
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Surface Combine or Crop option allows you to define the *SURFACE, COMBINE, or CROP.  The current version of Contact Manager does not have a Tcl/Tk dialog to define the surface combine or crop.  Review by highlighting or color change also does not work for these types of surfaces in Engineering Solutions.  Instead, it takes you to the corresponding Card Image panel for edit or review.
Click the edit button to go into the card editor to define all relevant keywords, parameters, and data lines.  When you are finished, click return and the Contact Manager window will once again be displayed.
