Engineering Solutions
Surface Interaction
Surface Interaction
This is the first topic This is the last topic No expanding text in this topic
Surface Interaction
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Surface Interaction dialog allows you to define the *SURFACE INTERACTION card with corresponding cards:
Mechanical interaction properties:
*SURFACE BEHAVIOR
*CONTACT DAMPING
*FRICTION
Thermal interaction properties:
*GAP CONDUCTANCE
*GAP HEAT GENERATION
*GAP RADIATION
This dialog contains the following tabs:
Define
Surface Behavior
Contact Damping
Friction
Gap Conductance
Gap Radiation
surface_interaction_define_3dtemplate
The Surface Interaction dialog contains the following buttons:
OK
Updates the Engineering Solutions database with the changes and closes the Surface Interaction window.
Apply
Updates the Engineering Solutions database with the changes without closing the Surface Interaction window.
Cancel
Closes the Surface Interaction window without any update.
See Also:
Contact Pair
Pre-Tension Section
Tie
General Contact
Auto Contact
Element Based Surface
Node Based Surface
Surface Combine or Crop
Cutting Surface
Analytical Rigid Surface
Abaqus Contact Manager
