Engineering Solutions
General Contact
General Contact
This is the first topic This is the last topic No expanding text in this topic
General Contact
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The General Contact option allows you to define the *CONTACT, *CONTACT INCLUSIONS, *CONTACT EXCLUSIONS and *CONTACT PROPERTY ASSIGNMENT. The keywords *SURFACE PROPERTY ASSIGNMENT, *CONTACT FORMULATION, *CONTACT CONTROLS ASSIGNMENT and *SURFACE PROPERTY CONTACT CLEARANCE ASSIGNMENT cards are available for Explicit template only.
ab-con-man21_gc
Click the Edit button in the Contact Manager to go into the card editor to define all relevant keywords, parameters and data lines.  When you are finished, click return and the Contact Manager window will once again be displayed.
See Also:
Contact Pair
Pre-Tension Section
Tie
Auto Contact
Element Based Surface
Node Based Surface
Surface Combine or Crop
Cutting Surface
Analytical Rigid Surface
Surface Interaction
Abaqus Contact Manager
