Engineering Solutions
Analytical Rigid Surface
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Analytical Rigid Surface option helps you define the *SURFACE, TYPE = CYLINDER, REVOLUTION or SEGMENTS card. When you select this option and click Create… the Analytical Rigid Surface dialog appears.
There are four tabs in this dialog:
Define
Adjust Normal
Rigid Body
Optional Parameters
analytical_rigid_surface_define
Each tab of the Analytical Rigid Surface dialog contains the following buttons:
Surface color
Changes the color of the current surface in the display.
Review
Reviews the current surface by highlighting line segments and generated revolute or swept surfaces in white. Right-click on the Review button to clear the review selections.
Close
Updates the Engineering Solutions database with the optional parameters that you specified and closes the Analytical Rigid Surface window.
