Engineering Solutions
Node Based Surface: Delete Surface Node Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
Node bases surfaces are displayed by special single node SurfaceNode elements. The Delete Surface Node tab allows you to delete the SurfaceNode elements.
There are two options for deletion: (a) All, (b) By node.
node_based_delete_surface_tab
(a) All option has the following buttons:
Delete
Deletes all SurfaceNodes elements from the current surface.
(b) By node option has the following buttons:
Surface nodes
Opens the Element Selector panel for you to select SurfaceNodes elements from the graphic area. The corresponding Reset button resets the selected elements.
Delete
Deletes the selected SurfaceNodes elements from the current surface
