Engineering Solutions
Tie
Tie
This is the first topic This is the last topic No expanding text in this topic
Tie
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Tie dialog allows you to define the *TIE card.  This dialog contains two tabs:
Define
Parameter
ab-con-man52
The Tie dialog contains the following buttons:
OK
Updates the Engineering Solutions database with the changes and closes the Tie dialog.
Apply
Updates the Engineering Solutions database with the changes without closing the Tie dialog.
Cancel
Closes the Tie dialog without updates.
See Also:
Contact Pair
Pre-Tension Section
Auto Contact
Element Based Surface
Node Based Surface
Surface Combine or Crop
Cutting Surface
Analytical Rigid Surface
Surface Interaction
General Contact
Abaqus Contact Manager
