Engineering Solutions
Node Based Surface: Define Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define tab allows you to define surfaces with individual nodes.  You can also define the surface by specifying a node set.  There are two available surface definition options:
Individual nodes
Node set
The layout of the Define tab changes based on your selections.
See Also:
Node Based Surface: Delete Surface Node Tab
Node Based Surface: Optional Parameters Tab
Node Based Surface
