Engineering Solutions
Alphabetical List
Alphabetical List
Alphabetical List
Panel
Accels
Create or update accelerations.
Acoustic Cavity Mesh
Generate fluid-volume meshes for acoustic testing.
Add Links
Add entities to existing connectors.
Admas
Create and update masses applied to nodes.
Altair OptiStruct
Write out Altair OptiStruct input files and then solve by clicking the optistruct button.
Altair Radioss
Execute an Altair Radioss run on your desktop from Altair HyperMesh.
ALE Setup
Create and modify input data pertaining to the Arbitrary-Lagrangian-Eulerian LS-DYNA capability.
Animation Secondary panel
Control the display of the model during animation sequences.
Apply Mass
Use a "dummy" connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data.
Apply Result
Apply a displacement result to the nodes.
Area
Create area-type connectors, such as adhesives.
Assemblies
Create collections of components.
Auto Cleanup
Performs automatic geometry cleanup and prepares it for meshing based on the parameters set in the panel.
Automesh
Interactively or automatically create meshes on surfaces.
Automeshing Secondary panel
A panel for most of the plate and shell meshing operations that allows you to work interactively on mesh parameters.
Axis Labels
Edit axis label information.
Axis Scaling
Modify plot axes.
Bars
Create or update bar2 or bar3 elements.
Beam Xsect
Calculate beam section properties.
Beamsection Collectors
Create components that group beamsections together.
Blocks
Create and modify block entities.
Bodies
Create and modify Altair HyperMesh group entities that correspond to Altair OptiStruct body definitions.
Bolt
Create and realize bolt connectors.
Border
Edit the border of an XY plot.
Build Menu
Redefine the layout of the Altair HyperMesh menu system.
Card Editor
Select the entities that are viewed in the card image subpanel.
CFD Tetramesh
Used to generate hybrid grids, containing hexa/penta elements in the boundary layer and tetra elements in the core or fare field.
Check Elems
Verify the quality of elements. Check warp, aspect, skew, angles, length, jacobian, connectivity, and duplicates.
Color
Modify the color attributes of collectors.
Compare
Compare connectors.
Component Collectors
Create components that group data together.
Composites
Align the element material angle of a mesh of shell elements and review material angle and ply directions.
Composite Size
Define manufacturing constraints for composite sizing optimization.
Composite Shuffle
Define manufacturing constraints for composite shuffling optimization.
Cones
Create a surface or mesh for cones or cylinders.
Config Edit
Change the configuration of existing elements.
Connectors
Create and manage connectors.
Constr Screen
Define data for truncation threshold and maximum number of constraints to be retained per region, per load case for a given response type.
Constraints
Create or update constraints or enforced displacements on nodes.
Contactsurfs
Create and modify contactsurf entities.
Contour
Create contour or assignment plots of results.
Control Cards
Edit solver specific data on a set of entities.
Control Vol
Create control volumes.
Convert
Exchange some data between different solver formats.
Count
Sums the entities in the database.
Curve Attribs
Create and edits curves.
Dconstraints
Create constraints for optimization problems.
Defeature
Remove surface features.
Deformed
Create deformed plot based on displacement results.
Delete
Delete data from the database.
Dependency
Find nodes that have multiple DOF constraints.
Dequations
Create user-defined functions for constraints and/or objective functions.
Desvar link
Link a design variable to other design variables.
Detach
Detach elements from adjoining elements.
Dimensioning
Change one or more dimensions of existing geometry
Discrete DVS
Define a discrete design variable value table for use in size or shape optimization.
Distance
Find the distance or angle between nodes.
Domains
Add and edit domains or update the model.
Drag
Create a surface or mesh by dragging nodes, lines, or elements.
Dummy
Rotate the dummy assemblies or specify the position of the H-Point of a dummy assembly.
Edge Edit
Perform many edge-specific operations such as suppressing or combining.
Edges
Finds free edges and equivalences nodes on edges.
Edit Curves
Create or edit new or existing curves from files or math expressions.
Edit Element
Build, combine, and split elements.
Elem Cleanup
Improve element quality of a selected region.
Elem Offset
Create solid elements or layers of plate or shell elements based on a plate or shell element by offsetting the shell elements in a direction normal to the surface they form.
Elem Types
Select and change existing element types.
Ellipsoids
Create and modify single or multiple ellipsoids and cylinders.
Entity Sets
Create sets of nodes or elements.
Equations
Create, review, and update equations.
Faces
Find free faces and equivalences nodes on surfaces.
Fatigue
Write stress/strain results from finite element analysis to an external file that can be used to set up fatigue analysis in a supported fatigue solver.
Finite Difference panels
Provide access to the Finite Difference panel.
FD Blocks panel
Create or modify Finite Difference blocks.
FE Absorb
Add (absorb) existing FE weld entities as realization to connectors.
FE Joints
Create, review, or update joints.
Features
Display the edges of a model as one dimensional plot elements, providing a visualization tool to see the edges of a complex model.
Find
Find entities (and IDs) in the database.
Flux
Create or update flux loading to nodes.
Forces
Create or update forces.
Freehand
Morph mesh without domains, handles, or morph volumes.
Free Shape
Define design domains for free shape optimization.
Free Size
Define design domains for free size optimization.
Gaps
Create or update gap elements.
Gauge
Create a single design variable (DESVAR) and multiple property relation (DVPREL1) cards for the components selected for size optimization.
Global
Specify the template file, current component, element order and size.
Grid Attribs
Edits grid information.
Grid Labels
Edits grid label information.
Handles
Add and edit handles, or save to or load from a file.
Hidden Line
Create hidden line and shaded image plots of elements.
HyperBeam
Define beam section entities before entering the HyperBeam module.
HyperLaminate
Launch the HyperLaminate module.
HyperMorph Constraints
Create constraints that restrict the movements of nodes or force compliance with dimensional requirements during morphing.
HyperMorph module
Prepare and morph models.
Altair HyperStudy
Parameterize solver models for performing parametric, optimization, or stochastic studies.
Connector Browser
Open a browser to display information on the models’ connectors.
Integrate
Integrate a curve.
Interfaces
Create and modify interfaces that define a contact or sliding surface.
Joints
Create, review, or update joint elements for MBD simulation.
Legend
Edit the plot legend.
Length
Determine the length of a group of selected lines.
Line Drag
Create a surface or mesh by dragging nodes, lines, or elements along a line.
Line Edit
Combine lines, splits lines at a point, at a joint, at a line, or at a plane, and smoothes lines.
Line Mesh
Create 1D elements between nodes or along a line.
Linear 1D
Create one dimensional plot elements.
Linear Solid
Create solid elements between two groups of plate elements.
Lines
Create lines using a variety of methods.
Load Collectors
Create components that group loads together.
Load on Geom
Map loads or boundary conditions from geometrical entities to associated FE mesh entities.
Load Steps
Create and update collections of load collectors.
Load Types
Select load types for new models or updates load types as defined in a template file.
Map to Geom
Map parts of the model to lines or surfaces.
Markers
Create and modify markers.
Mask
Mask entities from the display list.
Mass Calc
Obtain the mass, area, and volume of selected elements or surfaces.
Masses
Create or update mass elements.
Material Collectors
Create components that group materials together.
MBS Joints
Define kinematic joints between two local coordinate systems to connect two multibody collectors.
MBS Planes
Create rectangular, planar surfaces for use in multibody analysis.
Midmesh
Automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids or surfaces), without first creating a midsurface.
Midsurface
Extract the midsurface representation of a solid part.
Moments
Create or update moments.
Morph
Morph a model and create shape entities.
Morph Volume
Create and manipulate morphing volumes.
Morph Constraints
Set restraints on morphing.
Morph Options
Edit options that affect morphing behavior.
Multibody Collectors
Create components that group multibodies together.
Node Edit
Associate, move, or place nodes on a surface.
Nodes
Create nodes using a variety of methods.
Normals
Display and adjust the normal of elements or surfaces.
NSM
Add non-structural mass entities to a model, or modify existing ones.
Numbers
Display the IDs of entities.
Objective
Define objective functions for optimization problems.
OBJ Reference
Define a response and its reference values for a minmax (maxmin) optimization problem.
Opti Control
Control the optimization process.
Options
Determine tolerance, zoom factor, element shrink, pick handles, and so on.
Optimization Module
Perform topology, topography, size, and shape optimizations.
Order Change
Change elements from first to second order, or vise versa.
Organize
Move or copy entities between components.
Ossmooth
Extract and import the final design geometry from Altair OptiStruct’s topology, topography, and shape optimization results into Altair HyperMesh.
Output blocks
Create and update blocks of entities used for output requests.
Penetration
Check groups for initial penetration problems.
Perturbations
Setup shape optimization.
Permute
Switch x, y, z data of entities.
Planes
Create a planar surface or mesh bounded by planar lines.
Plot Titles
Edit plot titles.
Plots
Create new plots and select curves to include on the plot.
Point Edit
Add, move, and edit fixed points.
Points
Create free points using a variety of methods.
Position
Position entities in space by selecting nodes.
Preserve Node
Create, remove, and view preserved nodes.
Pressures
Create or update pressures.
Project
Project entities to a plane, vector, or surface.
Property Collectors
Create components that group properties together.
Quality
Perform FE quality checks.
Quality Index
Calculate a single value to represent the quality of the displayed shell (2D) model.
Query Curves
Find the x and y values of a point in a curve.
Quick Edit
Collects many tools for minor edits of model geometry.
RBE3
Create or update RBE3 elements.
Read Curves
Input an xy data set from an ASCII file.
Rebuild Mesh
Streamline the process of remeshing existing meshes to generate a new mesh with good quality and flow.
Reflect
Mirror entities about a plane.
Rename
Change collector names.
Renumber
Renumber entities.
Reorder
Change the order of named entities in the database.
Replace
Manually equivalence nodes.
Responses
Create responses for an optimization.
Results Curves
Create curves by extracting data from a Altair HyperMesh results file.
Ribs
Create and modify simple ribs between two surfaces.
Rigid Walls
Create and update rigid walls.
Rigids
Create or update rigid or rigidlink elements.
Rods
Create or update rod elements.
Rotate
Rotate entities about a vector.
Ruled
Create a surface or mesh from nodes or lines which are unconnected.
Safety Module
Contains the panels used for safety analysis.
Scale
Modify the size of entities.
Seam
Create connectors that represent line connectors.
Seatbelt
Create and route seatbelts onto a dummy.
Sensors
Create and edit sensors.
Shape
Perform shape optimization.
Shapes panel
Create and apply shapes to morph meshes.
Shrink Wrap
Create a loose or tight shrink-wrap mesh over a model.
Simple Math
Perform simple math functions on a curve.
Size
Setup and perform size optimization.
Skin
Create a surface or mesh skin across a set of lines.
Smooth
Improve element quality on a surface mesh.
Smooth Particle Hydrodynamics
Analyze the behavior or fluid or gas inside a meshed part.
Solid Edit
Trim/split or merge solid entities
Solid Map
Create a solid mesh by defining source, destination, and along surfaces.
Solid Mesh
Create a solid mesh within a volume defined by edge lines.
Solids
Create solids using a variety of methods.
Solver
Run an external program from within Altair HyperMesh or assign and run a solver.
Spheres
Create a spherical surface or mesh.
Spherical Clipping
Focus on a specific area of a model by displaying only the model inside a three dimensional sphere, masking everything outside the sphere.
Spin
Create a surface or mesh by rotating nodes, lines, or elements about a vector.
Spline
Create a surface or mesh with lines.
Split
Split elements into pre-defined patterns.
Spot
Create connectors.
Spotweld
Create or update spotweld elements.
Springs
Create or update spring elements.
Subcase
Generate Nastran and Altair OptiStruct subcase definitions.
Summary
Create a summary of elements, loads, and properties.
Super Elems
Assign nodes to a super element set and display the nodes of a super element set.
Surface Edit
Trim surfaces with lines or surfaces, untrims surfaces, and create surfaces that fill gaps in the model.
Surface Transparency
Set the transparency level for the surfaces of selected components.
Surfaces
Create surfaces using a variety of methods.
System Collectors
Create components that group coordinate systems together.
Systems
Create local coordinate systems.
Table Entries
Specify values for the constraints used in defining functions.
Tags
Assign names to entities.
Temp Nodes
Add or remove temporary nodes.
Temperatures
Create or update temperatures.
Tetramesh
Fill an enclosed volume with first or second-order tetrahedral elements.
Titles
Create and edit screen titles.
Topography
Setup and define topography optimizations.
Topology
Setup and define topology optimizations.
Torus
Create a toroidal surface or mesh.
Transient
Create an animation sequence from transient results.
Translate
Move entities along a vector.
Unrealize
Remove existing welds.
Updates
Displays version, update, and systems information.
User View Menu
Store and retrieve specific views of the current model.
Vector Collectors
Create components that group vectors together.
Vectors
Create a vector entity.
Vector Plot
Create vector plots from vector quantity results.
Velocities
Create or update velocities.
Window
Controls xy plot window size and placement.
XY Plots
Contains the xy plotting panels.
