Engineering Solutions
Using Altair HyperStudy with Altair HyperMesh
Altair HyperStudy can be used to perform Design of Experiments (DOE), optimization, and stochastic studies in a CAE environment.  It allows you to study the different aspects of a design under various conditions, including non-linear behaviors.  It can be applied in the multi-disciplinary optimization of a design combining different analysis types.
In addition to standalone use, Altair HyperStudy can be directly accessed from Altair HyperMesh by clicking HyperStudy from the Applications menu.
When Altair HyperStudy is accessed from within Altair HyperMesh, you have direct access to the Altair HyperMesh database to perform the design parameterization.
The following user profiles and solvers are supported:
Abaqus
ANSYS
LS-DYNA
Nastran
Altair OptiStruct
PAM-CRASH2G
Altair Radioss
The following entities in Altair HyperMesh can be accessed for the purpose of defining design variables:
Shell thickness
Spring stiffness
Concentrated Mass
Composite ply thickness
Composite ply angle
Shapes (as created by the HyperMorph module, or by the Perturbations panel)
In addition, models can also be parameterized using a base input template derived from the ASCII solver input.
See Also:
What is Altair HyperStudy?
Altair HyperStudy Graphical User Interface
Altair HyperStudy Tutorials
