Engineering Solutions
Surface Interaction: Contact Damping Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Contact Damping tab allows you to create *CONTACT DAMPING cards with corresponding parameters and data lines.  The supported parameters are: Definition and Tangent fraction (explicit only).  The two definition types supported are: Damping coefficient and Critical damping fraction (explicit only).  The data item entry options change based on the current template.  See the Abaqus Online Documentation for a detailed description of these parameters.
ab-con-man40
