Engineering Solutions
Surface Interaction: Gab Radiation Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Gap Radiation tab allows you to define a viewfactor versus distance relationship for heat transfer between surfaces which are very close to each other.
Emissivities for both involved surfaces can be defined. By default the dialog offers two datalines to define a function of the viewfactor depending on the gap with between two surfaces. The length of the table can be increased by changing the Number of datalines field.
gap_radiation_tab
