Engineering Solutions
Element Based Surface
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Element Based Surface dialog allows you to define and edit the *SURFACE, TYPE = ELEMENT card.  There are four tabs in this dialog:
Define
Adjust Normal
Delete Face
Optional Parameters
contact_mgr_surface_tab_define
The Element Based Surface dialog contains the following buttons:
Surface color
Changes the color of the current surface in the display.
Review
Reviews the current surface by highlighting in white and displaying it through solid mesh in performance graphics in the window.  If the surface is defined with sets, the underlying elements are highlighted.  Right-click on the Review button to clear the review selections.
Close
Updates the Engineering Solutions database with the optional parameters specified and closes the Element Based Surface window.
See Also:
Contact Pair
Pre-Tension Section
Tie
General Contact
Auto Contact
Node Based Surface
Surface Combine or Crop
Cutting Surface
Analytical Rigid Surface
Surface Interaction
Abaqus Contact Manager
