Engineering Solutions
Element Based Surface: Define Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define tab allows you to define surfaces for solid, shell, membrane, rigid, gasket, beam, pipe, or truss elements.  You can also define the surface by specifying the face identifier for an element set.  There are six available surface definition options for various element types:
3D solid, gasket
3D shell, membrane, rigid
3D solid coated with shell
3D shell - edge based
2D solid, axisymmetric, gasket
Beam, pipe, truss
Element set
The layout of the Define tab changes, based on your selection (displayed in blue).  Some options may be disabled depending on the current template.
