Engineering Solutions
Contact Pair: Parameter Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Parameter tab allows you to define optional parameters for the contact pair card.  Options vary according to the template loaded.
The supported parameters are:
For Standard.3d/2d template
Adjust, Extension zone, Smooth, No thickness, Hcrit, Tied, Small sliding and Type.  When the Type field is set to SURFACE TO SURFACE, the Geometric Correction field becomes activated. See the Abaqus Online Documentation for a detailed description of these parameters.
ab-con-man51
For Explicit template
Mechanical constraint, CPSET, OP, Weight, and Small sliding.  See the Abaqus Online Documentation for a detailed description of these parameters.
ab-con-man50
