Engineering Solutions
Individual Nodes
Individual Nodes
This is the first topic This is the last topic No expanding text in this topic
Individual Nodes
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Individual nodes option allows you to define the *SURFACE, TYPE = NODE card by specifying individual node IDs.  In the graphic area, these nodes are displayed by special single node elements with a SurfaceNodes tag.
Node_based_define_tab
The Individual nodes option has the following buttons:
Pick Nodes
Opens the Node Selector panel and allows you to pick nodes the graphic area. The selected nodes will be highlighted. The corresponding Reset button resets the selected nodes.
Add
Adds the selected nodes to the current surface and creates special single-node SurfaceNodes elements for display.  The Add button does not check for duplicates and there is no Reject button.
