Engineering Solutions
Node Set
Node Set
This is the first topic This is the last topic No expanding text in this topic
Node Set
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
This option allows you to define the *SURFACE, TYPE = NODE card for node sets. Engineering Solutions allows only one node set in a surface. It does not support combination of node sets and individual nodes in the same *SURFACE data line.
node_based_define_tab_2
The Node set: menu contains a list of the existing node sets.
The Node set option has the following buttons:
Review Set
Reviews the selected node sets by highlighting the nodes in the graphic area. Right-click on the Review button to clear the review selections.
Create/Edit Set
Opens the Entity Sets panel.  When you finish creating/editing the set, click return.  The Node Based Surface dialog is updated with the new set appearing in the node set list.
Area
This check box allows you to define the optional cross-sectional area at each nodes of the node set selected.
Update
Adds the selected node set into the current surface. Engineering Solutions does not create a display for surfaces defined with node sets.
