Engineering Solutions
Interface Tab
Interface Tab
This is the first topic This is the last topic No expanding text in this topic
Interface Tab
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Interface tab contains a description of the *CONTACT PAIR, *TIE, *PRE-TENSION SECTION, *CONTACT, and *SHELL TO SOLID COUPLING cards with corresponding surfaces and surface interactions.  You can create, edit, review, and delete interfaces from this tab.  You can also edit, review, and delete surfaces and surface interactions that are displayed on this tab.
contact_mgr_interface_tab
The Interface: table contains the following columns:
Name
The contact interface names. These names are not exported to the Abaqus input file. They are useful for identifying the various interfaces in Engineering Solutions.
Interface Type
The interface types. The currently supported types are contact pair, tie, pre-tension section, general contact, and shell to solid coupling.
Slave
The names of the slave surfaces in Abaqus Standard (or the first surface in Abaqus Explicit).
Master
The names of the master surfaces in Abaqus Standard (or the second surface in Abaqus Explicit).
Surface Interaction
The names of the surface interaction properties.
Slave display
The display on/off check boxes and color change buttons for the surfaces shown in the Slave column.  The color can be changed by clicking the color button and selecting a color from the menu.
Master display
The display on/off check boxes and color change buttons for the surfaces shown in the Master column.  The color can be changed by clicking the color button and selecting a color from the menu.
Note:
The display on/off check boxes and color change buttons are disabled if the corresponding surface is defined with sets and no displays are created for them.
Double click on the interface, surface, and surface interaction names in the table to open the corresponding edit windows.  Right-click on a name to display menu options.
Right-click on an interface, surface, and surface interaction name to display menu options. The available options are:
oEdit
oDelete
oSwap Master-Slave
oSwap CP-Tie
oReview
oReview with underlying entity
oReset review
oReview Options (Review by Highlighting, Review by Color Change, Transparency, and Grey Color)
oDisplay All
oDisplay None
oDisplay Reverse
oDraw Rigid Surfaces
The Edit, Review, Delete, Display All, Display None and Display Reverse options work like the corresponding buttons (described below).  Review with underlying entity highlights the surface along with the attached elements (or nodes).  The Reset review button clears the review selections.
Table columns can be resized by positioning the cursor along a column border, pressing the left or right mouse button, and dragging the border to a new position.
The shift or CTRL key and a left-click can be used to select multiple items in a table.
The Interface tab contains the following buttons:
Auto
Launches the Auto Contact dialog that allows you to quickly and easily create interactions between several parts of your model.
New
Opens the Create New Interface dialog in which you enter the name and type of the new interface.  The Same as: option allows you to create an interface by copying from an existing interface.  The Create button in this dialog creates the interface and opens the corresponding Contact Pair, Tie, Pre-Tension Section, Cavity Definition or Shell to Solid Coupling dialog.
ab-con-man49
Edit
Opens the corresponding dialog for editing the selected interface, surface, or surface interaction.
Review
Reviews the selected interface, surface, or surface interaction as follows:
For surfaces, the selected surface is highlighted in red in the Engineering Solutions window. If the surface is defined with sets, the underlying elements are highlighted. A right-click on the Review button clears the review selections.
For interface types, corresponding slave and master surfaces are highlighted in red and blue in the Engineering Solutions window. A right-click on the Review button clears the review selections.
For surface interactions, the names of all interfaces using the selected surface interaction in the table are highlighted. There is no graphical review in the Engineering Solutions window for surface interaction.
Delete
Deletes the selected interfaces, surfaces, or surface interactions.  You can delete single or multiple selections from the table.
Rename
Rename the selected interface, surface, or surface interaction.
Sync
Updates the Contact Manager with the current Engineering Solutions  database.  If you manually create, update, or delete components, groups, properties, or entity sets from panels while the Contact Manager is open, click the Sync button to update the Contact Manager with the new changes.
Close
Closes the Contact Manager.
Help
Invokes the online help for Abaqus Contact Manager.
See Also:
Contact Pair
Pre-Tension Section
Tie
General Contact
Auto Contact
