Engineering Solutions
Shell to Solid Coupling
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Shell to Solid Coupling dialog allows you to define the *SHELL TO SOLID COUPLING card. There are two tabs in this dialog.
Define
Parameter
contact_mgr_shell_to_solid
The Contact Pair dialog contains the following buttons:
OK
Updates the database with the changes and closes the dialog.
Apply
Updates the database with the changes without closing the dialog.
Cancel
Closes the dialog without updates.
