Orientation_angles
MDL-like methodThis version of the Orientation function uses Euler angles and an rm marker.
Function Name
Orientation
Usage
Orientation (angles=None, degrees = False, rm=None)
Arguments
angles
Double([], count=3)
Euler angles (Z,X’,Z’ rotations).
degrees
Bool
True for degrees. Default is False.
rm
Reference Marker
This marker is the relative reference frame used in the transformation of the Euler angles.
zp, xp = Orientation(angles=[90,90,0], degrees=True)
