Spdp
Model ElementThe Spdp element allows you to generate a spring damper geometry.
Class Name
Spdp
Attribute Summary
Name Property Modifiable by command? Designable?
i Reference (Marker) NO NO
j Reference (Marker)
da Double ()
db Double ()
dc Double ()
la Double ()
lb Double ()
lc Double ()
ld Double ()
coils Int ()
color String()
Usage
Spdp(i=Marker(), j=Marker(), da=10, db=20, dc=20, la=0, lb=0, lc=30, ld=30)
Attributes
i
Reference(Marker)
The marker that defines the attachment of the Spdp entity.
j
Reference(Marker)
da
Double()
The diameter of the spring.
db
Double()
The diameter of the damper at the I marker end.
dc
Double()
The diameter of the damper at the J marker end.
la
Double()
Defines the distance between the I marker and the end of the damper to which it is closest.
lb
Double()
Defines the distance between the J marker and the end of the damper to which it is closest.
lc
Double()
Defines the height of the damper at i.
ld
Double()
Defines the height of the damper at j.
coils
Int()
Specifies the number of coils to represent the Spring graphic.
color
String()
The color of the graphic for H3D animation. Specified as RGB (Red : Green : Blue).
  1. See Properties for an explanation about what properties are, why they are used, and how you can extend these.
