Engineering Solutions
Apply a Contour to a Streamline
1.From the Streamlines panel, follow the steps to create a:
-Line rake/streamline
Or
-Area rake/streamline
Or
-Plane rake/streamline
2.Go to the Contour panel.
3.Select a result type from the Result type drop-down menu.
4.Click Apply. The contour is applied to the streamline.
Note:Altair HyperView supports streamline contouring for nodal results only (elemental results are currently not supported).
See Also:
Streamlines
