Engineering Solutions
Rename a Rake
Rename a Rake
Rename a Rake
1.From the Streamlines panel, right-click the name of a rake in the Rakes list and select Rename (from the context menu).
2.Type a new name into the Rename dialog.
3.Click OK.
Or
1.From the Model browser, right-click the name of the rake in the tree (listed under the Streamlines folder) and select Rename (from the context menu).
2.Enter a new name in the name text field and press Enter. The rake is renamed.
See Also:
Streamlines
