Engineering Solutions
Surface Tab
Surface Tab
This is the first topic This is the last topic No expanding text in this topic
Surface Tab
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Surface tab contains a description of the *SURFACE cards with corresponding types.  You can create, edit, review, and delete surfaces from this tab.
contact_mgr_surface_tab
The Surface table contains the following columns:
Name
The name of surfaces in the Engineering Solutions database.
The types of surfaces.  Currently supported types are ELEMENT, NODE, and ANALYTICAL RIGID (SEGMENTS, CYLINDER or REVOLUTION).
Display
The display on/off check boxes and color change buttons for the surface.  The color of a surface can be changed by clicking on the color buttons and selecting a color from the menu.
Note:
The display on/off check boxes and color change buttons are disabled if the corresponding surface is defined with sets and a display is not created.
Double click on a surface name in the table to open its corresponding editing dialogs.
Right-click on a surface name to display menu options. The available options are
oEdit
oDelete
oReview
oReview with underlying entity
oReset review
oReview Options (Review by Highlighting, Review by Color Change, Transparency, and Grey Color)
oDisplay All
oDisplay None
oDisplay Reverse
oDraw Rigid Surfaces
The Edit, Review, Delete, Display All, Display None and Display Reverse options work like the corresponding buttons (described below).  Review with underlying entity highlights the surface along with the attached elements (or nodes). The Reset review button clears the review selections.
Table columns can be resized by positioning the cursor along a column border, pressing the left or right mouse button, and dragging the border to a new position.
The SHIFT or CTRL key and a left-click can be used to select multiple items in a table.
The Surface tab contains the following buttons:
Auto
Launches the Auto Contact dialog that allows you to quickly and easily create interactions between several parts of your model.
New
Opens the Create New Surface dialog, on which you enter the name and type of the new surface. The Create… button in this dialog creates the surface and opens the corresponding Element Based Surface, Node Based Surface, or Analytical Rigid Surface dialog or takes you to the corresponding Engineering Solutions card image.
ab-con-man10
Edit
Opens the Element Based Surface, Node Based Surface, or Analytical Rigid Surface dialog or takes you to the corresponding  Engineering Solutions card image for editing the selected surface.
Review
Reviews the selected surface.  Surfaces are highlighted in white and show up through solid mesh in performance graphics the window.   If the surface is defined with sets (display option disabled), the underlying elements are highlighted.  Right-click the Review button to clear the review selections.
Delete
Deletes selected surfaces. You can delete single or multiple selections from the Surface table.
Rename
Rename the selected surface.
Sync
Updates the Contact Manager with the current Engineering  Solutions database.  If you manually create, update or delete components, groups, properties, or entity sets from Engineering Solutions panels while the Contact Manager is open, click Sync to update the Contact Manager with the new changes.
Close
Closes the Contact Manager.
Display All
Displays all surfaces in the graphic area.
Display None
Hides all surfaces in the graphic area.
Display Reverse
Displays all unchecked surfaces and hides all checked surfaces in the graphic area.
Draw Rigid Surfaces
Shows analytical rigid surfaces in the graphic area.
See Also:
Node Based Surface
Surface Combine or Crop
Cutting Surface
Abaqus Contact Manager
