Engineering Solutions
Load Step: SRADIATE
Load Step: SRADIATE
This is the first topic This is the last topic No expanding text in this topic
Load Step: SRADIATE
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The SRADIATE dialog allows you to define the *SFILM card on Abaqus surfaces (*SURFACE).  To open the dialog in the Load Step window, select SRADIATE from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_sradiate
You can use Abaqus Contact Manager to create Abaqus surfaces.
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
