Engineering Solutions
Load Step: SRADIATE: Parameter Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Parameter tab allows you to define optional parameters for the *SRADIATE card.
The supported parameters are Amplitude curve, OP, and Region Type
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the optional parameter selection in the database.
See Also:
Load Step: SRADIATE
