Engineering Solutions
Load Step: Output Request: ODB File
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The ODB file dialog allows you to define and edit the output requests for the ODB file.  Supported keywords are: *OUTPUT, *NODE OUTPUT, *ELEMENT OUTPUT, *CONTACT OUTPUT, and *ENERGY OUTPUT.  To open the dialog in the Load Step window, select ODB file from the tree and an Output block from the  table.
The dialog contains five tabs:
Output
Node Output
Element Output
Contact Output
Energy Output
step_mgr_odb_output_tab.zoom81
See Also:
Output request
Abaqus Step Manager Overview
