Engineering Solutions
Load Step: Output Request: ODB File: Contact Output
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Contact Output tab allows you to define *CONTACT OUTPUT for the selected Output block. The following parameters are supported: Nlset, Master, Slave, General Contact, and Variable.  Activate/deactivate the check boxes in the tree on the Contact Output tab to add/remove identifier keys in the table.  The data lines added in this manner have a gray background, indicating they cannot be manually edited.  You may also add user-defined identifiers, by typing them directly into the table.  The user-defined data lines appear with a white background, indicating they are editable.
Right-click on the Data lines table to display menu options.  The available options are Cut, Copy, Paste, Add row, and Delete row.
step_mgr_odb_contact_output_tab.zoom87
The Contact Output tab has the following buttons:
Create/Edit…
Opens the Entity Sets panel.  When you finish creating/editing the set, click return.  The Step Manager is updated with the new set appearing in the node set list.
Review
Reviews the selected node sets, master surface, or slave surface by highlighting them in the Engineering Solutions graphics.  Right-click on the Review button to clear the review selections.
Update
Updates the Engineering Solutions database with the data lines defined in the table and the parameters.
See Also:
Output request
Abaqus Step Manager Overview
