Engineering Solutions
Load Step: Output Request: ODB File: Element Output
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Element Output tab allows you to define *ELEMENT OUTPUT for the selected Output block. The following parameters are supported: Elset, Position, and Variable.  Activate/deactivate the check boxes in the tree on the Element Output tab to add/remove identifier keys in the table.  Data lines added in this manner have a gray background indicating they cannot be manually edited.  You may also add user-defined identifiers, by typing them directly into the table.  The user-defined data lines appear with a white background, indicating they are editable.
Right-click on the Data lines table to display menu options.  The available options are Cut, Copy, Paste, Add row, and Delete row.
step_mgr_element_output.zoom85
The Element Output tab has the following buttons:
Create/Edit…
Opens the Entity Sets panel. When you finish creating/editing the set, click return.  The Step Manager is updated with the new set appearing in the element set list.
Review
Reviews the selected element sets by highlighting them in the graphics.  Right-click on the Review button to clear the review selections.
Update
See Also:
Output request
Abaqus Step Manager Overview
