Engineering Solutions
Load Step: Output Request: ODB File: Output
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Output tab allows you to define *OUTPUT cards with associated parameters.
Supported parameters are Field and History (in the Output drop down menu), and Name, OP, Variable, Frequency, Time marks, Number interval, Time interval, and Mode list and Filter under the Optional parameters list.
step_mgr_odb_output_tab
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the parameters defined in the database.
To enable the Node Output, Element Output, Contact Output, Energy Output and Radiation output tabs used to define their respective cards, you must first activate the corresponding check boxes.
See Also:
Output request
Abaqus Step Manager Overview
