Engineering Solutions
Load Step: Output Request: Data File (.dat)
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Data file (.dat) dialog allows you to define and edit the output requests for the data file.  Supported keywords are *NODE PRINT, *ELEMENT PRINT, *CONTACT PRINT, and *ENERGY PRINT.  To open the dialog in the Load Step window, select Data File (.dat) from the tree and an output block from the Output block table.
The dialog contains five tabs:
Define
Node Print
Element Print
Contact Print
Energy Print
step_mgr_data_file.zoom87
See Also:
Output Request
Abaqus Step Manager Overview
