Engineering Solutions
Load Step: Output Request: Data File: Energy Print
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Energy Print tab allows you to define *energy print for the selected Output block. The following parameters are supported: Elset and Frequency.
step_mgr_data_file_energy_print
The following buttons are available on the Energy File tab:
Create/Edit…
Opens the Entity Sets panel.  When you finish creating/editing the set, click return.  The Step Manager is updated with the new set appearing in the element set list.
Review
Reviews the selected element sets by highlighting them in the Altair HyperMesh graphics.  Right-click on the Review button to clear the review selections.
Update
Updates the Altair HyperMesh database with the data lines defined in the table and the parameters.
See Also:
Output Request
Abaqus Step Manager Overview
