Engineering Solutions
Load Step: Output Request: Data File: Element Print
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Element Print tab allows you to define *Element print for the selected Output block. The following parameters are supported: Elset, Position, Totals, Frequency, Last mode, Summary, and Mode.  Activate/deactivate the check boxes in the tree on the Element Print tab to add/remove identifier keys in the table.  The data lines added in this manner have a gray background indicating they can not be manually edited.  You may also add user-defined identifiers by typing them directly into the table.  User-defined data lines appear with a white background, indicating they are editable.
Right-click on the Data lines table to display menu options.  The available options are Cut, Copy, Paste, Add row, and Delete row.
step_mgr_data_file_elem_print.zoom74
The following buttons are available on the Element Print tab:
Create/Edit…
Opens the Entity Sets panel.  When you finish creating/editing the set, click return.  The Step Manager is updated with the new set appearing in the element set list.
Review
Reviews the selected element sets by highlighting them in the Altair HyperMesh graphics.  Right-click on the Review button to clear the review selections.
Update
Updates the Altair HyperMesh database with the data lines defined in the table and the parameters.
See Also:
Output Request
Abaqus Step Manager Overview
