The Node Print tab allows you to define *NODE PRINT for the selected Output block. The following parameters are supported: Nset, Frequency, Mode, Global, Summary, Last mode, and Totals. Activate/deactivate the check boxes in the tree on the Node Print tab to add/remove identifier keys in the table. The data lines added in this manner have a gray background, indicating they cannot be manually edited. You may also add user-defined identifiers by typing them directly into the table. User-defined data lines appear with a white background, indicating they are editable.
Right-click on the Data lines table to display menu options. The available options are Cut, Copy, Paste, Add row, and Delete row.
The following buttons are available on the Node Print tab:
Create/Edit… |
Opens the Entity Sets panel. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the node set list. |
Review |
Reviews the selected node sets by highlighting them in the Altair HyperMesh graphics. Right-click on the Review button to clear the review selections. |
Update |
Updates the Altair HyperMesh database with the data lines defined in the table and the parameters. |
