Engineering Solutions
Load Step: Inertia Relief
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Inertia relief dialog allows you to define and edit the *INERTIA RELIEF card.  To open the dialog in the Load Step window, select Inertia relief from the tree and a load collector from the Load collector table.
The dialog contains two tabs:
Define
Parameter
step_mgr_inertia_relief
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
