Engineering Solutions
Load Step: Inertia Relief: Define Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define tab allows you to define * INERTIA RELIEF cards.
Activate the Inertia relief check box to make the *INERTIA RELIEF load active for the current load collector.
There are two data line options available:
Free direction
Integer list of degrees of freedom identifying the free directions
Reference points
Global X, Y, and Z-coordinates of the reference point.
Click Update to activate the data line selection in the database.
See Also:
