Engineering Solutions
Load Step: Inertia Relief: Parameter Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Parameter tab allows you to define optional parameters for the * INERTIA RELIEF card.
The supported parameters are:
Orientation, Fixed, Remove, and None
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the optional parameter selection in the database.
step_mgr_inertia_parameter_tab
See Also:
