The following tools are available via the Aerospace menu, which is a useful utility to build and view aerospace models. The menu has minor modifications depending on the solver that is loaded.
Opens the following tools: Assembly from CSV, Module from CSV, and organizing Aerospace components. |
Panel |
Opens the Midsurface modeling (Midsurface Mesh dialog) tool. |
Beams |
Opens the Beams from lines, Beam Sections from CSV and Beam Auto Property tools. |
Composites |
Opens the following tools: PCOMP from CSV, Ply Geometry Smoothening, Ply Auto Rename, FE Absorb Plies, Material Orientation and Shell To Solid Conversion. |
Loads/BCs |
Opens the PLOAD1 Create and Review, Map Force and Mass, Line loads, RSpline and Transformation Tool. The Transformation Tool is also available by clicking Tools > Transformation Tool. |
Connections |
Opens the Fastener setup and Sewing Tools. |
Spatial ID Manager |
Opens the Spatial Renumbering tool. |
Display |
Opens the Orientation Review tool. This tool is also available by clicking Tools > Orientation Review. |
Results |
Opens the Matrix Browser and Results Explorer. The Matrix browser is also available by clicking Tools > Matrix Browser. |
Aeroelasticity |
Opens the Aeroelasticity Browser. |
Certification |
Allows you to input and save files. |
