Utility/Data Access
SubroutineUses the cubic spline fitting method to return the interpolated value or n-th derivative
of the interpolated value for a Reference_Spline element.
Use
The function can be called by any user-defined subroutine.
- Fortran Calling Syntax
- CALL CUBSPL (XVAL, ZVAL, ID, IORD, ARRAY, ERRFLG)
- C/C++ Calling Syntax
- c_cubspl(xval, zval, id, iord,
array,
errflg)
- Python Calling Syntax
- [value, eflag] = py_cubspl(x, z, id, iord)
- MATLAB Calling Syntax
- [value, eflag] = m_cubspl(x, z, id, iord)
Attributes
- ID
- [integer]
- The identifier of the corresponding user defined
- xval
- [double precision]
- The independent x value at which the cubic spline function is supposed to
interpolate the output value.
- ZVAL
- The independent z value at which the cubic spline function is supposed to
interpolate the output value for a 3-D spline data.
- IORD
- [logical]
- The order of derivative returned by the CUBSPL
function.
Output
- ARRAY
- The vector output value of dimension 3 that contains the computed
interpolated value y (for IORD equal to 0).
- If IORD is 1, then the returned values are the
derivatives of y with respect to x and z.
- If IORD is 2, then the output arrays contains the second
derivatives of dy in dx2, dxdz, and dz2, respectively.
- ERRFLG
- [logical]
- The logical variable that is returned to the calling subroutine and that
indicates the success of the CUBSPL function call.
