Meshing interface
The meshing interface is called by the Mesh organ button. It meshes the selected organ and writes it to a D00 file.
Name
Name of the D00 file which will be generated
Elements
Type of elements to generate: SHELL3N, SHELL4N, TETRA4 or SOLID BRICK
Slices, voxel and pixel
Divisions of Space
The organ is described by voxels (3D cubes representing a “thick” pixel). The number and the shape of generated elements are directly linked to the number of voxels and their proportions. The X, Y and Z values, describing the number of rows of voxels on each axis, can be modified to adjust the number of voxels describing the organ.
Use Image Real Ratio
Use the scanner values to compute the division of space and obtain cubic voxels. Allows the division of space modification by using the cursor.
Three different improvement types leading to improving elements quality and mesh biofidelity can be performed. you decide the number of application and the strength of the modification for each of them.
Raw Data Smoothing
Smooth the data obtained directly from the slices.
Smooth the 3D reconstruction obtained from the slices data.
• | Projection on surface: activate to do a last projection on the reconstructed surface without regarding the element's final quality. |
Elements Quality Improvement
Improve the element's shape and quality by moving the nodes locally.
