The HComfort distribution file contains a setup file (HComfort_V10b_WIN32.exe).
After installation, the HComfort directory will contain a script (see following) to launch HComfort and five directories:
exe/
Directory containing the executables.
icondir/
Directory containing the icons for the application.
lib/
Directory containing the libraries which are necessary to launch HComfort.
etc/
Directory containing the HComfort database.
doc/
Directory containing documentation in .pdf format.
HComfort contains:
• | an automatic installation script |
• | a README file |
To install HComfort, run HComfort_V1.0.b_WIN32.exe.
A complete path (target directory for installation) will be requested. HComfort will be installed in this directory and a launch script will be automatically created.
If you have any installation problems, please contact hwsupport@altair.com.
HComfort modules are started with run_scal_posit.bat and run_scan2mesh.bat scripts.
HComfort software is licensed using the FlexLm protocol. In order to be able to run HComfort on your system, you must:
• | obtain a FlexLm license filef rom Altair Engineering, Inc. |
• | have a FlexLm Altair daemon running on your system |
To obtain a FlexLm license file, please provide Altair with complete data about your machine. If you have any installation problems, please contact hwsupport@altair.com.
In case of any problem related to use or installation of HComfort, please contact hwsupport@altair.com.
