1. | From the Menu Bar, select LoadCase > Imposed Displacement > Create. |
2. | Enter a name in the Imposed Displacement Creation field and validate with Ok. |
4. | In the Selections folder, select nodes using the different tools from the Selection folder. |
Button
Behavior
pick nodes in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar.
add/remove object by ellipse selection.
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
add all nodes.
pick parts in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar.
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
add the parts selected in the tree.
remove the parts selected in the tree.
5. | In the Reference Axis folder: |
• | Click the Reference Axis folder. |
• | Define the reference axis using the different tools of the Reference Axis folder. |
7. | In the Properties folder: |
• | In the Scale factor field, set a scale factor for the abscissa of the defined curve. |
• | Set a starting time in the Start time field. |
• | Set a stopping time in the Stop time field. |
8. | Click Function to modify the function. |
• | Select Tx, Ty, or Tz to set the imposed displacement in X, Y, or Z direction. |
10. | Click Save to save the created imposed displacement; or |
Click Cancel to cancel the imposed displacement creation.
11. | Click Close to close the menu. |
Go to
