From the Menu Bar, select LoadCase > Imposed Displacement > Modify.
Button |
Behavior |
select all the imposed displacements. |
pick the arrow for the imposed displacement in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel |
select imposed displacements by box (use the SHIFT key to use a polygon box). |
pick parts in the graphic window to select all the imposed displacements applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel |
select parts by box (use the SHIFT key to use a polygon box) to select all imposed displacements applied to those parts. |
Click on the imposed displacement line in the listing window to select it. Several imposed displacements from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys |
Select only one imposed displacement and click for the option to do any of the following:
• | Change the imposed displacement name. |
• | Select or deselect nodes or parts (see Node selection). |
• | Modify the skew frame (see Reference axis). |
• | Modify the sensor (see Sensor). |
• | Modify the properties (see Properties setting). |
• | Modify the imposed displacement direction (see Direction setting). |
• | Click ![]() |
• | Answer the question in the pop-up dialog window with Yes or Cancel. |
• | Click Save to save the modified imposed displacement. |
or
• | Click Cancel to cancel the imposed displacement modification. |
• | Click Close to close the menu. |
