Note: | This option appears in any module in which a function can be set and defined. |
In the function window:
1. | In the Function name field, enter the name. |
2. | Click ![]() |
The following example depicts the format of a curve that HyperCrash reads from the input deck:
#RADIOSS STARTER 44
/FUNCT/1/<name of function curve>
X |
Y |
0 |
0 |
2 |
6 |
4 |
11 |
5 |
14 |
6 |
17 |
8 |
22 |
/END |
Only one curve should be stored in each file in the database.
3. | Select the directory path in the upper-left area of the file selection window. |
4. | Select the RADIOSS input deck file name in the upper-right area of the file selection window. |
5. | Click OK to import the function, or click Cancel to cancel the function selection. |
or
Select one of the already exiting functions of the model in the bottom area of the file selection window.
Note: | If the selected function is not displayed in the function window, check the information in the message window. |
6. | Manually define the new function: |
• | Set a time value in the field, t. |
• | Set the displacement value in the field, f(t). |
• | Validate both input values by clicking Validate. |
• | To modify a point: |
o | Select the line in the curve point list. |
o | Set a time value in the field, t. |
o | Set the displacement value in the field, f(t). |
o | Validate both input values by clicking Validate. |
• | To remove point(s) from the curve: |
o | select line(s) in the curve point list. |
or
o | Click ![]() |
o | Click ![]() |
7. | Answer the question in the Dialog menu bar with Yes, No, or Cancel. |
