Engineering Solutions
Tools Menu
Tools Menu
Tools Menu
The following features are available in the Tools menu:
Sets
Create, update and review named sets of entities.
Blocks
Create and modify a block entity.
Tags
Assign names to entities.
Titles
Create, edit and move screen titles and entity tags.
Delete
Delete data from a model database, preview and delete empty collectors and preview and delete unused property collectors, material collectors, or curves.
Card Editor
Select the entities that are viewed in the card image subpanel.
Organize
Reorganize your database by copying or moving data (entities) among collectors or includes.
Renumber
Renumber entities.
Count
Obtain a count of all the entities in your database.
ID-Manager
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
Model Checker
Checks the model for errors and warnings.
Quick Access
Quickly find and open the tools, panels and browsers that are available from the menu bar pull-downs or from the Utility browser.
Matrix Browser
Explore Altair HyperMesh and Altair HyperView data entities and export the entities to external files for further analysis.
Orientation Review
Display/review and modify frequently used coordinate systems used in CAE analysis.
Transformation Tool
Translate, scale, reflect or rotate elements with multiple numbers of copies including properties and loads attached to them.
Part Replacement
Replace the elements in an existing component with new elements; typically replacing a similar part remeshed or slightly reshaped.
Position
Specify a new position for model entities.
Reflect
Reflect portions of a model about a plane, changing the selected portion into a mirror image of itself.
Rotate
Rotate entities around an axis in space.
Scale
Increase or decrease an entity’s dimensions.
Set Browser
Automate the grouping and display of model components through the entity set functionality.
Solver
Run an external program from within Engineering Solutions or assign and run a solver on selected analysis decks.
Summary Template
Obtain a summary of component element counts or element properties of the current model.
Translate
Move entities in a single specified direction.
Component Table
Displays components and their associated attributes in an interactive table.
Material Table
Review and edit Altair OptiStruct materials.
Property Table
Displays properties and their associated attributes in an interactive table.
Load Collector Table
Review and edit Altair OptiStruct load collectors.
Loadsteps Browser
Create, manage and display loadsteps (sub-cases) and the associated control cards.
Create Cards
Shortcut to creating any available entity card within the program. Select the card to create from the list that appears.
