Drop Test has the following meshing capabilities:
Create a fluid volume mesh for the open-air volumes of an enclosed compartment, such as the passenger compartment of a vehicle. |
Create meshes or re-mesh existing meshing interactively or automatically on surfaces or groups of elements. |
Create, review or update bar2 or bar3 elements. |
Boolean Operation |
Connect intersecting 2D elements. This tool works for triangular as well as quadrilateral elements. |
Perform a model-based CAD-CAD, CAD-FE or FE-FE comparison between two models, or two selections of entities. You can also use this tool to find and report on geometrical/shape differences. |
Hand build, combine, split or modify elements. |
Create a surface and/or mesh by dragging a series of nodes or lines, or to create elements by dragging selected elements. |
Create and modify elements by offsetting from a mesh of plate or shell elements. |
EM Lattice Mesh |
Generate an axis-parallel mesh for 2D and 1D geometry input. |
Fuse |
Connect close proximity, overlapping, and intersecting parts. |
Create gap elements. |
Hole Detection |
Enables you to locate and define many, or all, holes in a model and add those holes as geometry to a new component or the current one. |
Hole/Gap Fill |
Mesh holes, gaps, and patches. |
Create a two or three dimensional surface and/or mesh or elements by dragging nodes, lines, or elements along another line. |
Create a chain of one dimensional elements such as beams along a line. |
Create one dimensional elements. |
Create solid elements between two groups of plate elements. |
Create mass elements. |
Mesh Controls |
Define one model specific mesh setting, as well as an unlimited number of local mesh settings. |
Midmesh Thickness |
Calculate the thickness of a mid-mesh from the solid geometry. |
Create nodes using a wide variety of methods. |
Periodic Mesh |
Generate a grid containing rotational and/or translational symmetric boundaries, for example rotating machinery. |
Calculates a single value to represent the quality of the displayed shell (2D) model. |
Quality Index Calculations |
The Quality Index value is a function of twelve criteria with user-defined weight factors. |
Quality Report |
Creates an HTML mesh quality report. |
Create, review and update RBE3 elements. |
Refine by Pattern |
Create a regular orthogonal mesh. |
Create rigid or rigid link elements. |
Create rod elements. |
Create surfaces and/or meshes of plate elements from nodes, lines and/or line segments, in any combination. |
Generate an enclosed volume or solid mesh and is typically used to approximate and simplify an existing mode. |
Create a skin surface and/or mesh from a set of lines. |
Create a mesh of solid elements in a solid geometric volume. |
Create a surface and/or mesh or elements by spinning a series of nodes, a line or lines, or a group of elements about a vector to create a circular structure. |
Create a shell mesh and/or surface. |
Create spring elements. |
Fill an enclosed volume with first or second order tetrahedral elements. |
TetraMesh Process |
Create tetra-meshes efficiently and effectively. |
Voxel Mesh |
Fills an enclose volume with voxels (hexas) of a predefined size. This type of mesh is only useful in topology optimization. It does not give meaningful results in a stress analysis. |
