Engineering Solutions
Sets
Sets
Sets
The Sets tab is enabled once comparison results are available. In this tab, you can create entity sets from the generated comparison results.
Source Entities/Target Entities
To create entity sets for the generated comparison results, select the Source entities and Target entities check boxes for the entity sets you wish to create. One entity set is created for each unique location-type-transformation grouping. A relevant transformation matrix for each grouping is attached as metadata to each entity set created, with the name CompareTransformationMatrix.
Name Prefix
In the Name prefix field, you can specify a prefix for the generated entity set names. Altair HyperMesh generates the set names as:
<prefix>_Transform<#>-<Type>-<SourcelTarget>_<#>
comparisontool_4
See Also:
Comparison Tool
Generate
Review
Results
